Sportster s Quadlock wireless charger fitting
Does anyone managed to fit Quadlock wireless charger on a Sportster S 2022 -later?
I have trouble with
1. My battery goes down very quickly
2. USB C port does not change my phone any more.
How to stop bike using battery when someone switched on the bike but did not switch off ? It happen to me when I parked and return from work my battery died by that reason. Show we carry battery tender changers all the time?
I have trouble with
I have trouble with
I have trouble with
How to stop bike using battery when someone switched on the bike but did not switch off?
If you meant switched on the usb socket that means you connected it to the wrong place in my opinion and you should have found a point that turns off with the ignition.
A USB socket contains electronics to step the 12 volts down to 5 volts. Any damp gets in will cause failure whilst switched on.
How did someone switch on the bike without you there?
Okay. I don't actually know your bike but mine has keyless ignition.
With no fob present I put the run / stop switch to run which turns on the ignition. After a couple of seconds the speedo shows enter pin. It flashes on the speedo for around 5 seconds after which the bike went back to sleep.
I would suggest any keyless ignition bike will do the same. If not either the fob is present or you need to go talk to the dealer about it.
commandozx
10-02-2021 03:03 AM
