99 Sporty speed sensor BOLT
If the cap head screw is replaced with a hexagon head one, it will indeed need a 7/16" wrench.
Rob Roy's Revenge (03-30-2023)
Perhaps cut a small piece of Allen and glue it to inside of a correct fitting 1/4 inch socket.
The glue keeps allen from falling out but double sided foam tape can work too.
Then use a 1/4 inch wobble tip socket extension.
The wobble tip will give you some angle.
Then use a wobble head 1/4 inch socket wrench.
The above should reduce potential stripping of bolt while providing some increased access.
