Decel pop....?
Received 5,438 Likes
thats the only thing ive changed
The following 2 users liked this post by Bobjv:
LordSargon (04-22-2023),
Rob Roy's Revenge (03-23-2023)
The following 2 users liked this post by Hey Man:
eighteight (03-23-2023),
The gaskets are not reusable, once used they must be replaced with new ones.
Also if care isn't taken when installing the exhaust, the gaskets can easily get damaged and they won't seal properly.
Check your plugs (color and condition) to see the lean vs rich vs just right operation.
Popping on decel is normal especially if you have a carb and aftermarket exhaust. It is not usually harmful. Let the plugs show you the way.
Plug Condition Diagnose
Popping in exhaust
Turned out to be loose nuts on the front exhaust.
I tightened them and everything was fine...for about 50 miles and it started again.
Checked and the nuts were loose, again.
Bought some new nuts, about 10k miles ago, everything is still fine.
