Oil light stays on.
on this style oil pump ,1976, the sender doesn't screw directly into the pump itself. There is a nipple that retains the check ball and relief sping, keeps the oil from sumping. The sender screws into that nipple. Both are just pipe thread. In FSM diagram #2 is the nipple. Currently there is a gasket between #2 and the pump body. That should not be there, according to the FSM.
Adding a gasket would influence the spring for the check ball.
Remember, adding a restriction increases pressure but reduces volume. I think that's the restriction to add enough press so light doesn't pop on at idle. It doesn't affect anything to engine and should not even bee needed at upper engine rpm.
When you remove the gasket, make sure spring and ball are there.
I thought the anti drain valve check was in the oil entrance?? Are they on the back side. An entrance from oil bag and a exit for the flexibility line to oil filter.
Harley's mostly have needle and ballbearing. Sporty has those sleeve bearings in the gear train. The don't need a lot of pressure nor will they hold it do to loose tolerances.
Just the as designed volume is enough to get oil thru motor.
Car motors are different in that they have volume that pushes thru all those close tolerance bearings. This creates pressure. The volume is however designed to have enough pressure to get oil to the furthest bearings in the heads. As things wear, failures occur. So they need probably three times what's engineered into a Harley.
Can't remember how many oil pressure sending units I have replaced in the past. There is no gasket for the sending unit, it's pipe threaad. Regular automotive unit won't work on an ironhead. Ironheads have hi volume low pressure pumps. Do I trust and "idot" light on my 77 XLH????
https://youtu.be/MeDymi0fOng Easy to see in this video the tiny hole in the nipple
I think it's straight thread and requires a face gasket. (From here). Sealer tap and such are really not designed for straight threads.
Probably doesn't hurt anything but if you use both, don't let it hang out on front of thread and break off. Last thing you want is it under that ball.
The center section has nothing to do with pressure switch. Later years have that pressure switch further forward mounted on side face of oil filter.
We just went round and round on that one. User had split case screwing it in two far.
I suggested he cap the crack with a thur bolt and gaskets. (Over other suggestions of welding). So of course, things went round and round and I added a few name callers to my ignore list. He capped it.
Relocate pressure switch on a T fitting. Where your pressure switch is was a discharge hose heading to filter.
Chris Restifo (03-19-2023)
There are 3 gaskets for the oil pump, taken from my Factory Parts Manual.
1 - 26256 - 52 pump to crankcase
2 - 26258 - 52 upper pump gasket
3 - 26259 - 62 bottom pump gasket
NO OTHER GASKETS ARE NEEDED
My Ironheads, PAST - 1972, 1975. Curreny 1977. So I've got a "little experiance" with the Beast.
I'm done here.
I'm done here.
I'm done here.
I'm done here.
UPDATE: I did finally get back to the issue. Took it apart ,pitched the useless gasket, problem SOLVED!!! Of course it would seem with these bike when they bought second hand, you fix one issue and find another one. During the process I discovered that at some point the check ball and spring had been completely removed!!! Now when the engine is cold the light does go out, but once it is hot, the light comes on at idle. Not sure what role the check ball and spring play in that issue. From what I read that is a gimme with these bikes, hot at idle, at least the light flickering? I will be getting the correct check ball and spring and installing them. But hey, the light goes off, that's progress, right?
Appears it is the idle fix for the light and anti-drain. If you look at PDF Page 2 closely. The ball check is overridden at speed. Later models are under the filter just for the light and the pump has the anti-drain there.
When you put a restriction in a line, it increases pressure. It does this by a loss in flow volume. At low idle speed, the pump doesn't have enough pressure without that slight restriction.
bet if your bike set a long time, the oil bag is emptied.
My old Softail if it sets much over 4 months, bag empties because the o-ring in the pump is worn I guess. It takes quite a few blocks of low-speed running to refill bag since it's also pulling oil out.
That oil pump design was used 59-69 and on a limited amount thru 76
Chris Restifo (03-21-2023)
