suddenly dropping oil
Trying to guess why my 2019 Sportster is suddenly dropping oil. I took it out for a first ride of the year, ran fine, but when I came out the next morning, small pool of oil under the bike. I can't figure where its coming from, I only feel oil on bottom of a tube running under motor. Ideas?
Received 6,055 Likes
M Oclaf (03-13-2023)
Start by checking the hose from the oil tank to the oil pump on the underside (right). You'll need to lay on the floor and look behind the exhaust up against the motor. The hose clamp on the intake side starts to leak.. Then check the drain hose from the oil tank. They leak after the rubber dries up. The air breather blow-by fittings are fed into the intake and if the BB builds up it'll leak onto your right leg. Those are the most common ones.
LordSargon (03-24-2023)
TUCCI (03-13-2023)
