Can a rusty tank be reliably repaired?
Is there a reliable way to save my rusty tank? I'm seeing people talk about using a handful of bb's and agitation to strip away the old liner, are there any other methods worth trying? What about the rust itself, is there a good way to remove all the rust or should I just trash the tank?
Thanks.
Thanks.
It is a simple process to remove rust from the inside of a fuel tank, POR 15 sells a chemical that will do the job.
If the tank has a liner that is failing, that must be removed first, and it can be a PITA, it has been a while since I cleaned the liner from the tanks on my 89 Softail, and I don`t think POR 15 sells the chemical anymore, I don`t know what people are using to remove the liner.
Once you get all the liner and rust out, just make sure the tank is full if it is going to sit for a long period.
I would not re line a tank once it is clean.
Yes.
It'll take more than a "handful" of BBs. I guess you could do it with a handfull if you have a couple of days. I think 3 to 5 pounds of BBs would be a good place to start. I use crushed rocks. (They won't rust;-) Disclaimer: I've never owned a tank with a liner so I can't say how well or fast it will remove a liner but you can sandblast or abrasive water blast pretty much anything that has to be removed.
BB's have no mass to be able to do much of anything not to mention and absolute bitch to ensure you get them all out again. I'd recomend using a couple dozen nuts and bolts along with vinegar, evapo-rust, clr etc. Make sure you count whatever you put in to aggigate to make sure you get them back out again.
Hawg295 (07-19-2023)
Received 5,438 Likes
