LA Choppers Clutch Cable Question
I am in the process of swapping to LA Choppers 13 Pullback Kage Fighter T-Bars. I ordered the recommended throttle, idle, and clutch cables as well as plug and play wire extensions. Everything has gone on fine so far, but when I opened the clutch cable, there is a long spring between the primary side clutch cable end and the bottom of the cable adjuster. For the life of me, I can not figure out why it is there. Does anyone have some insight for me?
I thought about that yesterday, as the stock cables don't have it so is it really necessary for either reason? The cable should take a nice sweep from where it clips to the frame not touching the engine and straight to the point where it enters the casing.
It will actually become a nuisance in time trapping dirt, IMO.
propflux01
11
11-18-2023 11:04 AM
