Need help!!!
Need help!!!
I am working on my nephews bike that has been in an accident and I went to fit the rear fender and it doesn't fit the best at all. The rear struts are bent and I need a huge favor from anyone, I need the measurements show in the picture. The picture isn't mine it is one I grabbed to show what I need. This is a 2013 Iron and I can't find any measurements online. Any help would be appreciated. A is measured between the strut mounts where it's welded to the frame, B is between the two strut cover bolts on the front, C is between the two strut cover bolts on the rear and D is from the tire to the strut where the bullet taillight mounts.
Thank you
Thank you
John Harper (03-05-2023)
What do you mean when you say it doesn't fit the best? If you mean the rear wheel is not centered in the fender that is just the way harleys are so you may be chasing a ghost. Many people complain about this. I thought mine were bent too when I replaced my rear fender only to learn my first leason of harley fit and finish...."well, that's close enough". Unless there are obvious signs of damage I would be willing to bet they are not bent. You should see how cockeyed my factory gas tank is. I had to buy an aftermarket tank to get a relatively straight one.
The following 3 users liked this post by OCSpringer:
I'm a little ocd and the sportster took some getting used to in that regard but in almost 30 years of riding the Sportster really has become one of my favorite bikes. They really are great bikes. Very reliable, fun to ride, and easy to work on.
Also notice the pic the OP is using for illustration was taken from somewhere else and no doubt someone asking the same question. In the pic the rear wheel is obviously not centered between the struts, but the struts are straight. Mine is exactly like the pic offset to the right. It's funny this came up because I had to remove my rear wheel over the weekend and was irritated by the fender. My tire almost rubs on the right side and has plenty of room to spare on the left.
Google "harley wheel not centered" and you will see countless threads on this. I am assuming they are all like this by design.
The easiest way to tell if they are bent is to fit the rear fender. If you can bolt it on they are not bent. In an accident, if one of the rear struts hit something and bent it would tweak the fender and likely not bend the other strut much if at all as the fender isn't very strong. Also I read those struts are cast. Not likely to bend. Break maybe.
Impalacustom (03-07-2023)
I want to thank everyone for advice and help.
So the bike was in an accident and it's Harley's fault because their world class fit and finish isn't good enough?
