Turn signal issues
Check rear bulb, then trace with a multimeter to see where current ends if bulb okay. My 1991 has only one signal indicator light (for both sides) on the speedo mount, do you have some kind of aftermarket speedo? My speedo does not have any turn signal lights integrated into it, they are below the speedo on the mount itself.
John
John
Wiring diagram for 1988 - https://serviceinfo.harley-davidson....1743498eb!!1!3
The problem is you are no longer stock with the change of speedo.
This thread could of gone on a while so it is good in the first post to state if you have modified or changed anything, IMO.
John Harper (03-03-2023)
