Bigger tank for 2020 Roadster
You will need to trim the seat a bit or get another seat. A few people have put 4.5 g tanks on 16+ Roadsters, Crusty at xlforum for one. Be aware the the actual capacity may not be 4.5 gallons, on my own 08 Roadster the bike will stumble if I accelerate and I've used about 3.5 gallons due to the EFI pump sucking air and I've read of some others with the same experience. A theory I read somewhere (that makes sense) is that when HD converted the tank to EFI in 2007 that they did not account for the difference in capacity due to the pump, filter, pickup vs. petcock etc.
Thanks to all, I think I have what I need. I thought the frame was the same, but I wasn't sure, and I didn't want to launch this project it the parts weren't going to fit. I plan to have an engine built with a bit more punch. Along with that I am going to put the 4.5g tank on (so I wanted to confirm that it would fit my frame without having to do a crapload of custom work). And yeah, I understand that I will need to change the seat, but Corbin, for example, makes it clear which seats work with a 4.5g Sporty, and which ones don't. 100+ HP, with 4.5g of gas, and a comfortable touring seat should be a good start on a light cruiser. Still gotta figure out the bags, and the rear suspension, but it is starting to look doable. Again, thanks for the input!
The following 2 users liked this post by slw210:
Rob Roy's Revenge (01-26-2023),
wlwoodruff (01-26-2023)
Received 1,638 Likes
as I do not see it listed anymore on the Baker website. It only worked for the 1991-2003 Sportsters.
https://bakerdrivetrain.com/collections/sportster/
good luck,
T.
What year Custom do you have ? FWIW, I think the Baker XL6 might be discontinued,
good luck,
T.
good luck,
T.
cacomly (02-09-2023)
I thought for sure I was going to go the larger tank route when purchasing my 2017 Roadster coming from mostly European brands. I have an MSR bottle that gives me .2 gallon extra fuel so I am fine with pushing it to the limits. This consistently gives me 160 miles- stock exhaust, stock intake, over 50mpg. On trips I tow my Bushtec trailer with 2-1/2 gallons in a roto-pax, see photo… which is needed in some parts of the west.
MSR bottle under the luggage rack…
The following 4 users liked this post by Adk.IBO:
hammer6315 (02-04-2023),
Rob Roy's Revenge (02-04-2023),
TheTraveler (02-05-2023),
WKNDS (02-05-2023)
I also carry MSR fuel bottles on trips. I have two of them mounted under the rack
in some Agri Manual canisters...
https://www.agrisupply.com/manual-ca...tyle/p/109316/
T.
T.
The following 2 users liked this post by cacomly:
08xl1200r (03-22-2023),
wlwoodruff (02-14-2023)
I put a 4.5-gallon tank on my 2007 Roadster and the low fuel light comes on at about 3.6 gallons. I still have the full 4.5 gallons still available. Of course, there could be other factors involved with how hard you are accelerating, is there a tank lift, suspension settings, etc.
I was looking hard at the new Roadster as my next travel bike also and may still go that route once I retire my 2006 Roadster and it's backup my 2007 Roadster from serving as a travel bike. Because of the extra weight I carry (6-gallon aux fuel tank, tourpak, saddlebags, etc.) I want the dual disc brakes up front. It's easier and cheaper to put a lager tank on a Roadster than it is to put dual disc brakes on a Custom/XL1200T. That is why I would go that route and suspect the OP feels the same way.
