are they tube or tubeless
Received 1,638 Likes
Originally Posted by 1HD1C
i understand this.. i was asking because i know the moco put out some tubless on spoked wheels and wasnt
sure what year that started
The following 2 users liked this post by RKZen:
1HD1C (01-22-2023),
eighteight (01-24-2023)
Generally..if its a laced wheel it needs a tube, If you go tubeless on laced wheel the air will escape where the spokes tie into the rim. Also when replacing tire or tube on a laced wheel, don't forget the large rubber strap that goes on the inside of the rim, it protects the tube from contacting where the spoke adjusters attach to the rim.
I didn't want tubes on my sportster so I ditched the spokes for mags. I also hated cleaning spoked wheels as well.
I changed both my road and mountain bike over to tubeless and they also need a special rim as well as the rim doesn't have the hooks like a normal rim does. It is an expensive change but the feel is worth every penny as you can ride lower pressures with tubeless as you don't have to worry about pinch flats.
that im tyring to do as cheaply as possible so mags currently arent in the cards UNLESS i can steal a set
on the cheap
The rim strip is thick and as wide as the wheel which is what allows you to skip the tube.
1HD1C (02-09-2023)
hall1836
02-21-2014 12:17 PM
