Cracked Oil Filter Mount - Screwed?
Rusty Springs (12-23-2022)
Received 5,424 Likes
It definitely can be welded by a skilled person. Doing it while the motor is still in the frame may be an issue, but anything is possible. You need to go to an old school Indy shop, a place that welds up old Knuck and Pan cases regularly. They will be able to tell you how to go about fixing that crack. But you may need to pull the motor, good luck.
The following 3 users liked this post by Architect:
Considering that the surface with the crack in it is a sealing surface, the chances of getting it welded properly, without pits, or other imperfections and remain flat and smooth are slim and none.
even accomplished welders I’ve known that have extensive experience welding aluminum would be hard pressed to get that spot done right.
Other methods should be pursued, IMHO.
evotrike (01-15-2023)
If I decide to go with Permatex Ultra Black, I'd cover the whole thing even inside. On the sealing surface it will have to be filed down flush. The oil switch itself - I'll cover it's threads with this stuff and screw it. It would be a pain in the azz to replace if it needed, but how often do you need to replace an oil switch...
M Oclaf (12-31-2022)
Received 6,055 Likes
hammer6315 (12-24-2022)
