SPORTY MISFIRING
RE: SPORTY MISFIRING
Like cHarley said, check the intake seals, spray wd-40 on them with the engine running, if you hear a change in the running then their's an intake leak. And exhaust leak can cause the same symptoms as well, so check that out too. How long ago has it been since the jetting was done, and why are you convinced the jetting is correct? Clean out the carb, the jets could be slightly varnished up. Another possibility is fuel, have you purchased gas from a different gas station lately? Try another brand of gas if you can. Citgo gas is one gas known to cause a waxy type build-up(simular to varnishing) in carbs because they skip a step in the refining proces. Shell is the best if available. The possibilities can be almost endless, but start off with the simplest things first. But since you have white plugs, it's a pretty safe guess to say it's most likely it's fuel or fuel intake related.
