1989 Sportster 883 ignition upgrade
Hello everybody
Hope someone can help. I own a 1989 SPortster 883 Deluxe (at least the documents and the VIN tell this).
When I started to investigate the upgrade to a Dynatek 2000i electronic ignition I found that my ignition looks like shown in the attached pictures.
Can anybody tell me what I need to do and what additional parts I need to be able to install the Dynatek ignition?
By the way, I don't have the timing inspection hole on the right side, but seems like there is one on the left side of the bike? Picture 3 shows the left side.
Thanks and kind regards,
Peter
Is this a little bit rusted screw the timing inspection hole?
Peter
Someone "upgraded" to older technology, points/condenser/mechanical advance weights. You need to buy an ignition that replaces those points and advance weights. I think the Dyna 2000i comes in a "nosecone" module version to do that. Mine still had the stock timing sensor, so I just bought the plug in module that replaced my stock one (under the triangle cover rear of battery). Someone stripped out your timing sensor and probably the module under the triangle cover as well.
John
John
Hi John.
You might be right, someone of the former owners maybe upgraded another bike with the original components of my bike and installed old ignition technology. Must have been a guy who knew a bit about these bikes.
Does this mean I can remove this old ignition stuff and install an original ignition rotor HD OEM Part No. 32402-83? Then the Dynatek 2000i would work.
Regards,
Peter
Regards,
Peter
From what I read, it would seem that is all you need, and maybe check the timing setting.
https://www.dynaonline.com/dyna-2000...odels-d2ki-1p/
John
John
TexasScooterTrash (05-31-2022)
Rabbigolem
11-12-2021 03:53 PM
jgcable
09-03-2009 11:48 AM
OhioSkully
10-04-2008 10:00 AM
