Jagg Slimline Oil Cooler Instal
I installed one on my '17 SuperLow a few years ago. I was seeing oil temps on hot (90*F) days at Interstate speeds right at 250*F. After installing the oil cooler under the same conditions I am lucky to ever see 220*F, most of the time oil temps are around 200*-210*F. I would go with Jaggs 4550 oil filter adapter instead of the one that comes with the kit. The 4550 adapter has a thermostat that does not open until oil temps reach around 185*F. That way you are not over cooling the oil. Worth every penny IMO.
I've since added stainless steel braided oil lines.
Attachment 612206
The 4550 adapter with oil lines installed.
Attachment 612206
The following 2 users liked this post by firehawk6:
Richnutt (05-12-2022),
Rob Roy's Revenge (05-10-2022)
I asked Jagg why I should purchase the 4550 adapter ( $150 ) over the one in the kit that has an oil viscosity valve that functions as a kind of thermostat. I purchased the slimline from of all places the Walmart web site for $309. Purchased the Jagg black braided 3ft hose kit from Amazon.
