Derby cover
Old 08-09-2007 | 09:20 PM
garye5007's Avatar
garye5007
Default Derby cover
I have '06 883C and I want to pick up someones take off derby cover probably off ebay to try some custom engraving... sorry if this a dumb question but i want to get the correct one . if its listed to fit say '04 and up sportster will it fit?... mine is a twin cam right? so if its listed for that should that fit? i'm trying to find a cheap one to try so if i screw it up no big deal. any help would be appreciated!
Old 08-09-2007 | 09:37 PM
Thongs2U's Avatar
Thongs2U
Default RE: Derby cover
04 & up will fit
Old 08-09-2007 | 09:45 PM
evilscotsman's Avatar
evilscotsman
If you're going to machine it yourself using a CNC machining center, may I suggest using MastercamArt to generate your engraving toolpath. It allows you to import clip art and generate 3-D machining planes if you're dealing with a domed surface. I use it a lot in my line of work as a tool and die maker. If you've got a pic or a rough ideaof what you're looking for and have access to theright machinery, I'll gladly generate your post and Mastercam file for you. If you don't have access to the machinery, get a hold of me and we'll talk. I could possibly be able to machine it for you.
Old 08-09-2007 | 11:05 PM
rbrunyan's Avatar
rbrunyan
ORIGINAL: garye5007
Any '04 and up883 or 1200 derby cover will fit as the case is the same for both engines however, yours is not a twin cam, that refers to an 88" or 96" v-twin as found in all the other bikes other than the sportster family. Good luck and post some pictures once you engrave them, never know, may be able to sell some.
P.S. Awesome signature evilscotsman!!!
Old 08-09-2007 | 11:10 PM
wannahdawg's Avatar
wannahdawg
i agree rbrunyan. twin cams refer to the big slow twins. but make sure to post pics, cause anything custom that you made, not bought, is cool as crap to me.
later,
wanna
Old 08-10-2007 | 06:21 AM
garye5007's Avatar
garye5007
Thanks all for your advice! ...evilscotsman, I'm using Type3 software to generate the toolpaths on a Datron high speed machining center. it has a z-probe to map out the curves or domed surface, i usually cut metal wih it but i've done some engraving.
thanks again for the advice and i'll post a pic if i can make something that looks halfway decent!
NWTruck
02-23-2019 02:51 AM
gtrplyr
Milwaukee Eight (M8)
09-24-2017 08:13 PM
Keithhu
07-19-2017 01:12 AM
HDV-GLIDE
10-17-2011 08:33 PM
Derv
05-18-2010 06:44 PM
Quick Reply: Derby cover
