so to all that use the pv
where and how do you have it mounted?
What gauges are you using?
i use the bar mount but i do also have the perch mount just like the gauges close together better.
i use the rpm volts temp and mpg settings
I have mine mounted next to the left side switch housing on my apes using a chrome tech mount for a clean look...i use rpm,gas used,miles gone,and avg mpg.next screen is engine temp,throttle position,and timing on both cylinders.love it.
