Sportster 1200
Sportster 1200
I've been working in the primary of my 1991 sportster 1200 I took it completely apart all the way even pulling the gears from the tranny I've gotten it back together but now I only have 1 down and 3 up while shifting what could be causing it to not go into forth any help is appreciated thanks
FUJILICIOUS (05-26-2021)
But the OP reports one down and three up which is exactly what you would expect to find on a four speed bike . One down , one up through neutral to second , up to third and up to fourth . Anyway , thanks for the reply . 😁👍
Midpegs (05-27-2021)
Received 22,120 Likes
FYI:
https://bikez.com/motorcycles/harley..._1200_1991.php
Displacement: 1198.0 ccm (73.10 cubic inches) Engine type: V2, four-stroke Power: 58.0 HP (42.3 kW)) @ 5200 RPM Top speed: 155.0 km/h (96.3 mph) Compression: 9.0:1 Bore x stroke: 88.8 x 96.8 mm (3.5 x 3.8 inches) Valves per cylinder: 2 Fuel control: Overhead Valves (OHV) Cooling system: Air
Gearbox: 4-speed Transmission type,
final drive: Belt
final drive: Belt
