1969 xlch
1969 xlch
Hi, I’m working on a 69 XLCH with a magneto and it has a cycle elect. Voltage regulator that I believe does not work. I had the generator tested and it works, but when I connected the voltage regulator the head and tail lights it does not work.
if I connect the lights to a 12 v battery all the lights work great.
is there a particular generator that is used for a XLCH with a mag ? And a particular CYCLE Elect regulator I should use?
thanks
john
thanks
john
back again (05-14-2021)
