Front brake question for you mechanically inclined individuals
Old 08-03-2007 | 12:54 PM
stevegray's Avatar
stevegray
Default Front brake question for you mechanically inclined individuals
I think I am having some manner of problem with my front brakes. A few days ago the front brakes started to feel different. The braking does not feel as smooth as it did before and the lever does not seem to be pulling back as far. Plus when you are pulling back on the lever it sort of feels like it is trying to push itself back out, at least that is the best way I can describe it.
I haven’t got the chance to take off the caliper and inspect the brake pads yet but looking at them from the outside they seem to have plenty of pad left. The rotor does not have any obvious defects.
What should be my next action here if the pads do not appear to be damaged?
Thanks in advance for your help.
Old 08-03-2007 | 01:48 PM
capttawes's Avatar
capttawes
Default RE: Front brake question for you mechanically inclined individuals
If it brakes fine and the lever does not feel mushy indicating air in the line then it's fine. You could always just bleed the brakeline and see if it feels better.
Old 08-03-2007 | 03:17 PM
HOTLAP's Avatar
HOTLAP
Maybe you have had an air bubble in there allthis timethat has just now worked it's way up to the reservour and now the lever feels like it should have all along.
Old 08-03-2007 | 04:31 PM
tjones's Avatar
tjones
I think I read in my manual somewhere that the caliper slide pins should be inspected and or replaced every four years. That is where I would start if not still under warranty.
Old 08-03-2007 | 05:09 PM
SportyPig's Avatar
SportyPig
Sounds like maybe the brake line needs to be bleeded, and the fluid replaced.
Old 08-03-2007 | 06:03 PM
bigtop1's Avatar
bigtop1
Sounds like theproblem is in the hydralics and agree with sportypig that you should bleed the front brake line.
Old 08-03-2007 | 07:08 PM
stevegray's Avatar
stevegray
Thank you gentlemen, you've just determined what my Saturday afternoon will be.
smithbrl
08-04-2020 07:32 AM
boygenius
EVO
16
07-30-2014 07:29 PM
LateBloomer
22
04-30-2010 05:05 PM
Chumplestilskin
08-10-2009 10:31 AM
mgoblue3
06-26-2008 11:01 AM
Quick Reply: Front brake question for you mechanically inclined individuals
