Primary cover question
I hit a patch of sand/gravel coming to a stop and layed my 14 xl883n down today, resulting in a bent upwards shift lever shaft and I’m gonna attempt the repair myself and I have newbie question? Do I need to drain my oil in order to take off the primary cover to get to the shaft to swap it out??
thanks in advance
jeremy
thanks in advance
jeremy
Yes , you will need to drain the oil to remove the Primary Cover . The shift shaft is easy to remove and with care it could be straightened in a vice possibly with the application of some heat . Disclaimer : I am not an expert in this matter so you might want to price up a new or second hand shaft .
Jeremy Wells (05-06-2021)
The following 2 users liked this post by Madnss:
eighteight (05-07-2021),
LordSargon (05-06-2021)
