Intermittent Spark
Did you have both spark plugs out and grounded against the heads?
The EFI Sportsters (07 and later) will not fire the spark plugs while cranking unless the ECU detects a slowing of the crankshaft from the compression stroke.
You can use spare plug(s) (or a spark tester) to check for spark while cranking the engine with the existing plugs still installed in the heads.
