Primary fluid drain & fill
So I’ve got a 03 883, just got it. I’m dropping all three holes and when I take the derby cover off I find a retaining clip sitting at the bottom of the cover. After taking a look I’m not sure where it is from, without tearing in deeper. I admittingly don’t have any manuals yet, they are on the way. In the meantime anybody here have some ideas on what it should go to exactly?
I hate to tell you this but the only retaining clip I know of that looks like that is on the end of the starter Bendix gear . You won't find it in the manual * because HD like to pretend that the gear cannot be separated from the starter clutch . That said , I fail to see how it would function with the clip missing . It's the one on the extreme right . * 04 Roadster .
1. I'm pretty sure Sportsters only have 2 holes to change primary and trans share the same oil.
2. Looks to be part of the spring as you have stated, might want to get a new one from the dealer.
3. Looks to be a witness mark on your clutch adjuster from where the spring broke and the sharp end marked it.
The following 2 users liked this post by CoolBreeze3646:
Bobjv (04-08-2021),
Hammerhead Pat (04-07-2021)
