Lowering a sportster - HELP
Send the seat to Mean City Cycles and they can lower the height by replacing the foam with better, thinner material and they can narrow the seat as well. I had this done to the seat on my Road King and it came out great. IIIRC, the lowering was about 1".
Good boots will also help, as mentioned above.
Received 1,637 Likes
This is the standard seat that comes on a XL1200T. Looks can be deceiving. The side is around 3" tall but the bit you sit on is only 1" to 1.5" thick in the middle.
Link to HD - 2020 Harley-Davidson SuperLow 1200T Motorcycle | Harley-Davidson Europe (harley-davidson.com)
I agree with what others have already said. Try working with
the seat first before you mess with "short" shocks. There is
the High Dollar HD "Reach" seat you might reasearch, but if it
comes to having to lower the rear, a cheap way is to use an
adjustable lowering block. This would allow 1" - 2" lower
by moving the lower shock mounting point rearward.
This is not a great pic (really old), but it looks like the following.
You can see how the lower attachment is alot further rearward.
good luck,
T.
good luck,
T.
