i got a 2000 1200c sporty that im wanting to put some little led lights inside the mirrors to use as front blinkers. all the lights i see come with a ground wire and a hot. will they blink if i plug them into the original blinker wires or is it a lost cause. also the rear blinkers wont blink, the just stay on, is it cause the front ones arent hooked up and they run on the same circuit. any help or advice would be cool.
I had the same problem whenI installed mini bullets on my '96. As DaveJ stated above, you will need a load equalizer. I purchased one from my local stealer for approx 35 bucks. It is a badlands product and it is actually called a load equalizer II. I have had very good luck with this product and recommend them highly...
E
well thanks for all the input, ill get the equalizer asap. as far as the blinkers in the mirror idea, i guess since you can buy them that way i wont do it myself. thanks for your help
