Step Jack
Old 01-04-2021, 03:24 PM
John Harper's Avatar
John Harper
John Harper is offline
Received 1,974 Likes on 1,346 Posts
Originally Posted by slickman
can’t tell what you made it from. any more pics and maybe one with the bike on it?
I used a piece of 3/4" plywood, two pieces of 2x4 and four deck screws. I think I have a pic, and will try to post up later when I get home. Bike balanced perfectly, did not even strap it down.
John
Old 01-05-2021, 06:17 AM
boomerguy's Avatar
boomerguy
boomerguy is offline
Originally Posted by templeofdank
i had a step jack roll and the bike fell off, i was able to hold it from dropping but still scared the **** out of me.
https://www.discountramps.com/motorc...ack/p/MC-JACK/
i have one of those, it works super well. not as sturdy as a proper lift, but it's easy to use and does the job. i've had my bike on it all winter so far while i've been rebuilding.
I have one of these under a different brand name. Once I figured out how it works, it does great. With my Honda Shadow, I could start lifting as soon as one side of the frame touched the jack. It was very easy.
This was not the case with my Sportster; I learned to raise the jack until it just barely touches the left side of the frame and then straddle the bike to make it level and then I continue to raise the jack while I straddle the bike while using a socket wrench with extension to clear my leg. For some reason (maybe the extreme lean angle of the Sportster?), when I DO level the bike the whole frame is less than one inch above the jack and it is much easier to lift. If I DON'T level the bike first, the left side of the frame is much higher than the right side and makes raising the jack extremely awkward. .
Old 01-05-2021, 06:59 AM
John Harper
Here's a shot of my bike on the lift, notice no tie downs needed.
John
Old 01-05-2021, 10:32 AM
08xl1200r's Avatar
08xl1200r
08xl1200r is offline
Another bike on jack photo (the aluminum one from HF) Works well but does need a strap for security, I need to make some sort of cradle myself, Sportsters are very prone to tipping when lifted since the frame is so narrow. Still use my DIY step jack if I only need to lift the front wheel but in general think they are more suited to much lighter bikes, especially if you don't have a helper when lifting the bike.
DresserDude
"The Florida Crew"
10-02-2012 01:20 PM
dfndr
11-20-2010 02:27 PM
sparky_mo
02-03-2010 10:14 AM
jarhead45
07-24-2008 11:15 AM
Harley Al
Harley Davidson Videos
02-11-2006 02:06 AM
Quick Reply: Step Jack
