Directional Relocation Rear Turn Signals
Has anyone used the HD kit to relocate their rear turn signals. Part number 68474-04B or 73281-10.
I’m trying to run thrashin supply bags on my Nightster, but I need to relocate the stock RBT bullet signals back to add clearance for the bags.
I have a chopped fender that isn’t cut in a straight line, so using a license plate relocation kit isnt an option.
trying to get a visual of how the HD kit would actually look.
also try to figure out if there is a way to run a sissy bar with the relocation kit...likely going to have to fabricate brackets for the sissy, but without a visual I’m having a hard time judging what I need to retrofit the sissy bar to work w the relocation kit.
You will probably have to use this kind of bracket for the sissy bar.
Sissy BAR Side Plates Chrome, for Harley - Davidson Sportster 04 - Present | eBay
HD #53925-04
From the installation notes you can see the new bracket has a hole about half way between the normal mount and the back most fender bolt.
How will it look? The indicator will just be moved back by that amount.
HD #53925-04
^Wolfman^
08-14-2019 12:33 PM
Stanger
02-15-2007 02:35 PM
