Braking Is a problem ??
Received 2,201 Likes
Exactly why I made my comment which is counter to what boomerguy is implying wearing out his back brake all the time.
So to answer the OP, braking is usually only a problem if you don't see what is happening in front of you. If you accelerate at a green light that has been green for sometime then you could be in for a bit of a moment if it goes red!
You need to try and see a hazardous situation before it happens and ride defensively such that the brakes aren't tested every time you need to stop.
Insane Mega Stoppers
Front:
Dual contoured Arlen Ness Big Brake Kits,
touring master cylinder,
full custom hand built braided Russell lines,
touring calipers,
lyndall Z+Pads,
Prestone Dot 4 (varies by year but, I went overboard)
Rear:
EBC contoured rotor,
Lyndall Z+Pads
2007
2013
Adsun (12-07-2020)
Most of braking comes from front . These heavy Harleys do not brake and handle like bicycles. On a Harley, in a straight like, heavy braking stops from the front mostly. Back helps but beware of rear lift. That rear will lockup in a heart beat and you don't even know it with a lot of non squeel tires. In a turn, it tries to catch the front tire and you will find yourself sliding down the road.
As far as comparing bicycles to motorcycles. The same laws of physics apply to both. I've been riding bicycles since 1955 and I still ride road and mountain bikes over all types of terrain and in different types of situations. I've been riding motorcycles since 1964. The first motorcycles were bicycles with a motor installed inside the frame which is exactly why the Harley engine is at 45 degrees, so it would fit. This forced the need for a single-crank pin, and narrow engine which is top heavy. Same physics. Apply the front brake harder than the rear in a turn, with or without gravel, and see what happens. This is why I said to experiment with a bicycle at slower speeds that has both, a front and rear brake.
Yes, cars have disc brakes on the front because there is a need for greater braking up front. That does not change the need for starting with the rear brake and then increase the front brake AS NEEDED, but don't apply it first. Even using only two fingers on my front brake, I can stop my bike on a dime in a straight line by maximizing the front brake.
Dude. Braking is only a problem when you expect more from them than they will give.
In time you will get a feel for them, take it easy and don't rely on the rear brake to slow down, use MORE front brake than rear when going straight to slow down.
Practice front brake in a parking lot, many many times at different speeds.
Use rear brake in parking lots and slow stuff.
Later on you will use rear only a tad once you get a good feel for cornering...
YOU DONT NEED ABS, I have spoken
This is a given. It does not go against what I said. The bottom line is to NOT put yourself into a situation where you have to brake in a panic situation.
Have only been down once. Was 16, going across a footbridge no less to impress my squeeze who lived across a creek in WV. Hit the first part of the bridge too hard and the front tire bounced up and to the right onto the soft bank. Slid down the soft bank into the creek. Was on a 250 Zundapp.
Year older than you. Guess it depend on bike. I had a VStar with dual front rotors. That bad boy was like power brakes. My Softail takes more than two fingers on the front. I have never though about hitting the rear and then the front. I just grab them both. However, I drive easily.. Never speed and when people cut in front, I just keep backing off. That takes old age to learn that. Fifty years ago, I slide tires on everything I owned and did not know why?
I didn't mean to give the impression that I don't use the front brake at all. I always use both brakes at the same time. I just use less pressure on the front brake lever than I do on the rear brake pedal. There is ALWAYS pressure from my two fingers, just less of it. I use my front brake for supplemental braking and I have had to use maximum pressure on it more than once but fortunately, not that often. When my foot is on the pedal, my fingers are on the lever just in case.
I cannot remember when I did something stupid but many have did it to me. I was in a blind turn. Traffic was stopped in on coming lane. One had given some distant and waved at a car to my right on the shoulder come across and get in. They saw him wave and didn't process could they and suddenly they were in front of me.
I came down on both brakes. It slammed me so hard fwd that my foot slammed the rear. What's crazy is rear locked, and came around on my right. Driver saw me and stopped. That turned me and someway I managed to get around in front of him using that open space without going down. Had no choice. If I had hit the guy waving, however, it would have been my fault.
However, it really hard to practice such craziness. And at my age, my bike is more a static pretty piece of art.
It probably would be in my den if RIP had not taken it over with her sewing hobby. My man cave is upstairs and I have yet to figure how to get it up there.
Adsun (12-21-2020)
