Need info about my forks
Here's my experience:
My bike wiggles in high speed curves... I think I need to do more in the front I dunno.
Maybe need a tad more rear preload cause I have it all the way loose to account for the stiffer springs, again I dunno. But I plan to Add a fork brace and some gold valve emulators later on. I can live with it like it is for now.
here is what I did:
I put longer damper rodes in, by Tracker Die, it raised my front end 2 inches, I'm still on my factory springs and used screaming eagle fork oil. I also replaced the rear shocks with 13.5" HD off of a Roadster.
here is what I did:
Did you get the speed wobbles after getting the tracker die damper rods? If so did you have it at the 9.5 or 11.5 height setting? How was it prior?.
I have an 07 1200L and was thinking of getting the tracker rods put on and heavier fork oil. Based on those results possibly add the racetech w emulators. Or I might go roadster rods and add the racetech
Hey I went with the 9.5. It was 4.5 prior and actually ended up adding 2 inches in the end.
No Speed wobbles, but I do get some slight shaking at very high speeds like 100 to 110 but that could be the windshield or tire.
I did not add emulators, but kinda wish I did.
jeffbetrollin
01-22-2017 12:46 PM
