Changing Seat Foam
RE: Changing Seat Foam
you need to cut out the old foam where you want to put the new in, use the best hospital grade foam you can find the less resistance/stiffer it is the better. cut it just a hair bigger than what you cut out it will compress....
http://www.efoamstore.com/shopcart2/default.asp?id=10
this link doesnt give the grade of the foam if its not a 2
I wouldnt think about it..... you can send a message and ask the seller, I got my last foam off ebay for 7 bucks.
http://cgi.ebay.com/Hospital-Grade-F...QQcmdZViewItem
Darkrider1695
07-14-2013 07:41 PM
