10,000 mile maintenance. Self done!!!!!
[*]I can do a lot of this stuff on my own but need help with others if anyone knows of a good web site please let me know......!!!!!
Change engine oil and oil filter. [*]Inspect air cleaner and service as required.[*]Clean tappet oil screen.[*]Change primary chaincase lubricant and clean magnetic drain plug.[*]Check/adjust primary chain.[*]Check clutch adjustment.[*]Change transmission lubricant and clean the magnetic drain plug.[*]Check and adjust belt.[*]Lube the foot shift/brake lever bearings and speedometer cable.[*]Check rear brake pedal adjustment.[*]Inspect brake pads and discs for wear.[*]Check brake fluid reservoir levels and condition.[*]Inspect oil lines and brake systems for leaks.[*]Lubricate the front brake hand lever, throttle control cables, throttle, clutch control cable and hand lever and jiffy stand.[*]Lubricate Springer steering head bearings.[*]Check, adjust operation of enrichener.[*]Inspect fuel valve, lines and fittings for leaks.[*]Clean fuel tank filter screen (carb. only).[*]Check operation of all electrical equipment and switches.[*]Check battery electrolyte level and clean connections.[*]Change spark plugs.[*]Check tire pressure and inspect tread.[*]Check wheel spoke tightness.[*]Repack wheel bearings with grease.[*]Inspect, adjust, repack front fork bearing.[*]Change front fork oil.[*]Repack rear fork bearings.[*]Adjust Springer rocker bearings.[*]Check condition of rear shock absorbers.
Check stabilizer links and engine mounts. [*]Check tightness of all fasteners except engine head bolts.[*]Check ignition timing and vacuum hose.[*]Check engine idle speed adjustment
In addition to the service manual get the "Fix My Hog" DVD, about $45. It walks you through all the regular service procedures with tool requirements, torque specs. etc. http://fixmyhog.com
10000, 2003, 2007, 883r, classic, harley, hd, maint, maintainence, maintenance, maintnence, mile, service, sportster, ultra
