RE: F'd up the clear on the fork tube taking reflector off
thanks; I ain't much for fishin, so I didn't have any line, but I do a lot of coke, so I used a razor blade to get started, then squirted wd40 on the goo.
The reflectors were applied soon after it was painted or coated. There will always be a slight indentation. I took off my rears and cleaned up nicely. Installed a sissy bar. I'm leaving the fronts on. Don't want to get hit on the side.
You do know the reflectors need to be there for state inspection in Pa unless you find a dishonest mechanic?You can still get pulled over for them being missing and fined.
