I have a 1998 1200 custom that if you get over about 75 mph will cutout and die, when you slow up and shift down to 4th gear it will start up and run fine as long as you don't go to fast again. Had carb overhauled and still.does it. Thoughts? Thanks.
Sounds like it is getting starved for fuel. Could be venting. It could be the petcock screen, or your vacuum is dropping enough to allow the petcock to close (if you still have a vacuum actuated petcock)? The more your throttle plate is open, the less vacuum being created.
