Raising Sportster Ride Height
FWIW, I have a 2007 XL1200L and I did exactly what you did: cheap 13" rear shocks from a 2007 R and [longer] damper rods in the front... which is the same as what your spacers accomplish. Longer damper rods part number 45925-04.
I think using used shocks on a bike is like using a used condom you found in an alley.
Although if you are going to go with used shocks, put a set of touring bike air shocks in the back. Should be able to pick up a set of new take off's for about $100 and they will ride much better than the stock shocks.
Received 4,899 Likes
I don't know if your 08 low would get the same results,but I've just fitted 13" Hagon Shocks to my 12' superlow & haven't noticed any ride/handling problems without changing the front height,that's not to say that the front wouldn't benefit from better springing,but the ride height seems ok & the bottom of the frame looks pretty level.
No the preload is not insane. You do know that the 2008 Roadster has longer damper rods, which is equivalent to spacers. In fact, all models have the same fork tube length but different damper rod lengths. That's what makes the L and the R models sit at different heights in front.
pretty sure compressing the spring down more into the same space will increase the preload.. but what do I know
If you are still concerned, then go my route: replace your damper rods with new ones from Harley, part number: 45925-04.
HTH.
DAZ883
12-21-2012 04:49 AM
