Sometimes when my nightster sits for a while and i turn the on switch to run and the fuel pump hums. that hum sometimes turns into a high pitched squeal. i'm just wondering if this is normal or if i should have it checked out?
Mine does the same thing if it is low on fuel and has sat for a while too. Once it is filled up with fuel I hear nothing. ( It only does it occassionally tho)
Mine makes the normal hum for about 4-6 seconds to bring the system up to operating pressure then shuts off, you hear the same thing with most fuel injected cages.
The high pitch squeal is not normal though, I would be concerned with that.
