Big guy sportster shocks
Bitubo shocks are great, a little pricey but good springs and adjustable dampening.
https://traxxion.com/product/bitubo-shocks-wme-for-harley-davidson-motorcycles/
Call ask for Dan, he will get you a better price.
The only difference on the install is additional washers are required because the air shocks are fatter. I had mine on a yr before I sold the sportster. Never an issue with mine. these have coils in them. At 180lbs I ran with zero air when solo
OP may have a budget...has $1200 into the entire bike?
IMO best option, as mention above, used bagger Air Shocks $80
(FWIW Buy the proper inflator, these shocks may only need 2 to 12 psi adjustments)
I think the cheapest Progressive brand name new shocks are around $250.
Used shocks can take searching for a while, E-bay knock offs may result is poor compression/ rebound/ spring rate et al, which said c/r/sr may be the reason the OP is looking to upgrade.
Good luck.
Good luck.
My 2014 Ultra has the OEM air shocks. My bike weighs almost 900 gassed up, and I weigh 180, yet I run only 10psi solo in my shocks (13") and have ridden 2 up at that same pressure, although, 12-13 would probably been better, for 2 up. It was a very soft ride, but a little too soft. Never bottomed out though.
My point being, with me, solo, on a 900 lb bike and only using 10 psi, it would ride very harsh on a sportster, anywhere near that pressure. I had RK 13" air shocks on my sportster, and ran them at zero. Handled very well and nice ride too. I found 6-7 was good for 2 up on the sportster.
Remember, these are sprung for a solo rider about 180lb, on an 800+ lb bike.
jordanball33
07-13-2011 07:52 PM
