NEED HELP ASAP! 2009 iron 883 power loss
So the bike sat outside for a week we had a lot of rain, had cover on it a few holes whatever. Got home started the bike up immediately thought it sounded strange took it for a ride and have bad power loss sounds weak. Realized I got blow by into my
oil tank so I did compression test and it’s good both cylinders ran same pressure. When I take the plug wires off it seems the front cylinder is working harder than the back. Changed plugs wires and coil no change, so I swapped the injectors to see if the Problem would change cylinders but it didn’t. ANYONE have any ideas???
HarbourLightsCreative
04-07-2013 07:33 PM
