dk custom Thunder Torque inserts
decides to try them on my VH straight shots no baffles the popping was about to cause me to buy full baffles. tried el cheapo thumbs screws just to see. tried different angles couldnt really tell most likley they was to small the popping argh just gonna happen with fully open pipes. so went with the DK'S and much improved got them at 90 degrees and quieter overall and the popping down maybe 80% worth the $
azgrumbles (08-21-2020)
Coyotebody - had the same problem installing them in my Wife's 04 1200 Custom. Remove the baffle and slip the heat shield on. Mark the baffle hole from inside the pipe onto the inside of the heat shield. Move that mark to the outside of the heat shield and drill it out. Put the heat shield back on and then install the baffles. You are welcome . . . in advance AND ya'll owe me a beer. Went out to the garage to look 2 times. LOL
Genius, will drill the heat shields this week! I’ve been riding around baffleless terrorizing my poor neighbors, hopefully the tt inserts will quiet him down and allow me to keep the performance.
was not sure if they would make the exhaust sound deeper/more aggressive. Somewhere between stock and removing the baffles and installing the tti.
blueridge
02-25-2013 11:22 AM
