I think my ‘17 Roadster’s forks need attention...
A rougher ride could be as simple as a missing balance weight causing a wheel to vibrate, or even well worn tyres. Take a good look around and see if you can get a better idea of what the source may be. It's difficult to see why your forks should be the cause!
Of course Ohlins also make suitable fork cartridges, so it is certainly worth trying them....
Thanks guys. No corrosion, curbs or dirt riding here. New tires this season, I will check wheel weights... 50,000 mile service interval surprises me. Maybe I need to play with my shocks a bit and I will look into Ohlins forks to compliment the shocks. No idea where to get the cartridges..
They would have to be made of rock! I also use longer mileage tyres, Avon Storms, but they are just fine. There must be something else going on I suspect.
I’m lucky to have a good Indy for the last 25 years, he told me at 25,000 the fork oil is to be replaced. We discussed a set up from Racetech (springs and emulators). Since I am not a real aggressive rider and just wanted a smoother, less harsh ride. He said it came with 15 weight oil, he put 10 weight in and under filled by 10ml. I am quite satisfied with the ride now with that and Ohlins on back.
