Chain Conversion? for 200mm
Old 07-22-2020, 04:05 PM
jeemann99's Avatar
jeemann99
jeemann99 is offline
Default Chain Conversion? for 200mm
Has anyone done a 200mm conversion on their Sporty? I have emailed 3 different companies regarding this and they don't have an offset sprocket to accommodate a 200mm wheel.
Plus it brings the tire back a few inches, so the questions are?
- where do I buy the kit
- front sprocket spacer
- how many link chain
- if i want more torque to mid what size sprockets do you recommend
thanks in advance
Old 07-22-2020, 06:54 PM
Madnss's Avatar
Madnss
Madnss is offline
Received 1,108 Likes on 591 Posts
thanks in advance
I run a 180 with a chain, could probably fit a 190, not sure about a 200. I didn’t buy a “kit”
Vulcanworks or pbi for your sprocket needs and spacers. Chain length depends on how much the arm is extended.
You fitting a sport bike wheel up?
id run 520 o or x ring chain and not 530.
ham_slam (12-08-2020)
Old 12-08-2020, 03:11 PM
ham_slam's Avatar
ham_slam
ham_slam is offline
1st Gear
Do you use a 5.5 Rim for the rear? If so, did you need an offset sprocket?
Old 12-08-2020, 04:32 PM
WKNDS's Avatar
WKNDS
WKNDS is offline
Received 1,364 Likes on 987 Posts
Note: I saw this when surfin' the web, I've never used anything from them.
If your German translation is good, you might check out Ricks Motorcycles
for a wide swingarm to get you started....
https://ricks-motorcycles.com/en/par...ung-sportster/
good luck,
T.
Madnss's Avatar
Madnss
Madnss is offline
I think it’s 5.5, I’ve ran a Buell tuber wheel with a 180 and currently running an xb wheel with a 180. Yes, 3/4” offset sprocket from Vulcan works.
Old 12-08-2020, 06:12 PM
ham_slam's Avatar
ham_slam
ham_slam is offline
1st Gear
okay I appreciate it! It seems there is no information about this.
Old 12-09-2020, 07:45 AM
Threeheadedshadow's Avatar
Threeheadedshadow
Threeheadedshadow is offline
Im getting things ready for a 180 rear tire conversion. I plan on keeping the OEM belt. Vulcan also sells offset transmission pulleys. This is the route I will go if I need to kick the belt out to not rub on the tire.
https://secure.vulcanworks.net/store...n-Pulleys.html
Old 12-09-2020, 11:27 AM
back again's Avatar
back again
back again is offline
Received 6,398 Likes on 2,584 Posts
I’ve done a 200 tire with both chain and belt. Low Brough and LED Sleds both sell pkgs along with another few suppliers. Used 5.5 wheel and had no clearance issues with either set up.
Old 12-09-2020, 11:47 AM
ham_slam's Avatar
ham_slam
ham_slam is offline
1st Gear
So you got the one from low brow and it fit fine? I have it now but it says it’s meant for stock wheel and rim. Not sure if I needed an offset sprocket.
Old 12-09-2020, 08:40 PM
back again's Avatar
back again
Defiantly need offset sprocket.
belt. I’ll get a picture of the chain sprocket when I get home Friday.
Quick Reply: Chain Conversion? for 200mm
