bill1200xl
Old 07-15-2020 | 03:09 PM
bill1200xl's Avatar
bill1200xl
2nd Gear
Default bill1200xl
I'm riding a 2013 1200XL. When I turn my key to "ignition" nothing happens. I turn it to "accessories" and everything lights up as usual. Obviously I can not start my bike. It was working perfectly all morning and now it's not. Battery is fully charged, Any ideas?
Old 07-15-2020 | 08:52 PM
TexasScooterTrash's Avatar
TexasScooterTrash
Is the Kill Switch on?
Old 07-16-2020 | 04:09 AM
Andy from Sandy's Avatar
Andy from Sandy
"nothing happens" by which do you mean the lights go out?
Old 07-16-2020 | 08:29 AM
bill1200xl's Avatar
bill1200xl
2nd Gear
Yes, lights on in "accessories" position and then lights off in "ignition" position and start button doesn't even make a sound.
Old 07-16-2020 | 08:31 AM
bill1200xl's Avatar
bill1200xl
2nd Gear
Good question but yes I checked that.
Old 07-16-2020 | 08:40 AM
Andy from Sandy
Looking at the wiring diagram - https://serviceinfo.harley-davidson....t/view?id=5540
the ignition switch when in the IGN position should connect accessories. It would appear that the switch might have failed.
You should check that all the fuses are good and no pins are corroded first.
If you have a multimeter disconnect main fuse and check continuity of the switch by going from main fuse to Lights, ACCY or ignition fuses.
Old 07-16-2020 | 09:00 AM
bill1200xl's Avatar
bill1200xl
2nd Gear
Thank you, I will try that. I was going to check the fuses later today. This happened very suddenly with no intermittent problems.
Old 07-16-2020 | 01:06 PM
bill1200xl's Avatar
bill1200xl
2nd Gear
All the fuses look like new. The same with the battery cables. I only have about 4500 miles on this bike. My son has my multi-meter so I couldn't follow your other suggestion. I was hoping it might be something obvious so I wouldn't need to bring it to Harley service where it will sit during these nice weeks of summer and also have to tow it in. I appreciate your help though.
Old 07-16-2020 | 05:17 PM
Andy from Sandy
Just looking at the wiring diagram of the ignition switch you can see where it goes from ACC to IGN + ACC. You say you loose everything when you put switch to IGN position looks like the switch has gone if all the fuses are good.
Obviously you need a meter to confirm that.
For what you need a $10 special will do the job. Accuracy is not important it just needs continuity or ohms range.
Old 07-17-2020 | 04:40 AM
grbrown's Avatar
grbrown
Sounds more like a wiring problem than anything else. Does your bike have non-stock handlebars, or have you disturbed the handlebar switches recently? Are there any mods to your bike at all?
Quick Reply: bill1200xl
