1200 C tire wear
1200 C tire wear
For what it's worth I'll give you my tire wear experiencefor no other reason thanyou can compare it to your experience. I bought my05 1200 Clast April with 1300 miles on it. At 10,000 I replaced the front and now with 15,000 I'm having the rear replaced this coming Tuesday.
RE: 1200 C tire wear
I replace both the front and rear Dunlop's on my bikes at around the 10,000 to 11,000 mile mark.
Usually there is still quite a bit of tread left on them (especially the rear), but I put a lot of higher speed interstate miles on my bikes and like to have 'fresh tires'.
ORIGINAL: whaap
ORIGINAL: Buda
You would think the rear would wear out before the front. What gives?
ORIGINAL: whaap
ORIGINAL: whaap
I know. That has been my experience in the past with bikes I've owned. The best I can figure out it is two things. One, the tire on the front is extremely narrow compared to the rear and, two,most of the miles I put on my bike are in the twisties and because of the counter steering involved with the front wheel in cornering that is the reason for the faster wear on the front.
ORIGINAL: Buda
ORIGINAL: whaap
ORIGINAL: whaap
ORIGINAL: Buda
ORIGINAL: whaap
If you use the front brake more than the rear (which most do), it will accelerate the slight scuffing/tread wear on the front tire.
And as was already mentioned, the narrower front tire has a smaller footprint to distribute the weight of the bike and rider.
Also, look at the initial new tires tread depth of a tire.
For example;
A new Dunlop D401 16" rear tire has a tread depth of 10/32", while a new Dunlop D402 21" front tire has a tread depth of only 5/32".
Normally a tire with a tread depth of 5/32" will wear out quicker than a tire with a tread depth of 10/32".
