Battery pigtail.
I'm going to be hooking up a pigtail to my battery so I can plug in my battery tender and also to plug in my 12 volt air compressor which I will use in conjunction with my stop-n-go tire plug gun.
For those of you that have this hook up, where do you have the business end of your pigtail coming out of the bike for easy access?
ORIGINAL: OldFenderGuy
This is where I had it on my 1200C.
Didn't stick out where it was 'noticeable', but was still easy to access. When not being used I just tucked it in behind the case.
![](http://dogsdoom.com/PI/1200-plugin.jpg)
if its a softtail,coming out from under the seat on right side and laying on top of the oil bag.about 6-8" .Cant be seen and easily accessible. May want to put some fingernail polish on the battery connections so they wont vibrate loose(been using it for years on most electrical connections)
Under seat, left side. Will reach to up between the tank and seat, making it easy to plug in your heated vest also!!!!!
I found this little item at Walmart for $3.00. Now I can use the GPS with the voice directions or charge my cell phone.
couldn't upload until Amanda slew the picture gremlins !!!!!!!!!!!
[IMG]local://upfiles/20003/E21AE109CEDC41BCBC9E45576A8F9B3F.jpg[/IMG]
salty_rider
04-16-2015 06:14 AM
