2015 sportster base gaskets
Hi bought a 2015 883 low that had a dealer installed 1200 kit at 1200 miles. Now has 3,000 miles and the base gaskets are leaking a little on the gear shift side. There is no oil dripping but it has left a film of oil right at the base gaskets. There is no weeping on the brake side. Do you think I could just retourqe the heads or do I need to take it all apart and put new gaskets
Thanks in advance
PS there is no warranty as I bought used. Already checked.
Thanks in advance
Gaskets
hi bought a 2015 883 low that had a dealer installed 1200 kit at 1200 miles. Now has 3,000 miles and the base gaskets are leaking a little on the gear shift side. There is no oil dripping but it has left a film of oil right at the base gaskets. There is no weeping on the brake side. Do you think i could just retourqe the heads or do i need to take it all apart and put new gaskets
thanks in advance
ps there is no warranty as i bought used. Already checked.
thanks in advance
apache snow (07-28-2020)
base gaskets
