Unknown Noise: rear brake dragging?
My '07 1200 Custom has a weird noise every so often....mostly during/after a long ride.
It sounds like the rear brake is dragging and making a "wurring" noise.
This happens at very low speeds. It's not quite like the sound of "slight brake dragging" but more of a "wurr".
The "wurr" is not like a wheel bearing "wurr...wurr...wurr", it's more like a 'harmonic' wurr...if that makes sense....
This only happens after I've been on the bike for more than an hour of riding time or so....and of course does not happen all the time.
I'vegot ~1,700 miles on the bike and it's probably happened 3 times total....
What do yaa think?
What do yaa think?
RE: Unknown Noise: rear brake dragging?
I hear the same noise on my 07 nightster. I like to kill the engine late at night while coasting into my driveway so as not to wake the neighbors, with the engine dead and coasting, I can hear the brake pucks dragging on the rotor. It is normal for the pads to lightly drag, you would hear it on a car if you were close enough to the brakes.
I hear the same noise on all my motorcycles...but the Harley is the loudest of all. I think it is that withmost bikesyou have a chain whirling and drowning out the brake drag noise whereas the Harley has a nice quite belt. You also have to remember Motorcycles use high metallic pads that are noisier then automotive pads.
