HF lift
Could you rig this? https://www.harborfreight.com/4-ton-...ack-69472.html
Might it be similar to the cylinders used for engine hoists? Summit racing sells replacement cylinders for those - https://www.summitracing.com/search/...lacement-parts. There are also others to be found if you do a browser search for "long ram hydraulic jack". Harbor Freight sells a couple too - https://www.harborfreight.com/3-ton-...ack-36468.html
John Ha (01-23-2020)
Not being snarky but this would have been a really great post if you'd included information about where to get the parts. I've some experience trying to find parts to refresh a floor jack (not a Harbor Freight unit) and I had a terrible time trying to find the right seals for it.
I have the same problem with a Craftsman lift.....the jack "release" is stuck in the release position......no replacement available. I am going to try adapting a standard 2 or 3 ton bottle jack to the lift mechanism. I have lots of tools including welders so I should be able too.....just have to use the hands to release the jack instead of the foot.
