Stage 1 on new 1200C?
Picking up my 2007 1200C tomorrow night. They already have the Screaming Eagle pipes on them. It was suggested to me by a friend who has ridden Harley's all his life to have them put the Stage 1 kit on my bike before I pick it up. Is this something I should consider? Keep in mind, this is my first motorcycle AND I am female. Will this be a mistake? Will it really make a difference that at some point I will want? Should I just have it done before I even get used to riding the thing. (I do plan to stay in parking lots, etc....for awhile, don't worry: I won't be jumping on an interstate anytime soon!)
Thanks!
Thanks!
RE: Stage 1 on new 1200C?
Many people consided or call Stage 1 a performance upgrade. It really is not. Stage 1 removes what the EPA did to cripple the bikes performance to meet federal regulations. It lets the engine breathe and perform like it was designed to do and will not only run better but cooler.
I think you might want to get used to it first. Then later, during a servicing, have it added. Until them maybe try to find some that has stage one and see if you like it. After you get plenty of experiance and if they will let you ride it.
I am not sure, but I think if you get the stage 1 and don't like and want to go back, you have to replace the whole carb. Thought I read something about them having to drill something out.
Anyone else know?
Anyone else know?
ORIGINAL: coyyai
Anyone else know?
Anyone else know?
ORIGINAL: cHarley
Sorry but, the above is total misinformation from someone who doesn't have any actual first hand knowledge.Since you have an 07 you don't have a carb. to begin with, let alone any stage 1 work done to a carb. or EFI can be undone.
ORIGINAL: coyyai
Anyone else know?
Anyone else know?
And just to pick you brain a little since you know, how can you tell if a carb has stage 1? I just got a 2001 XL1200C a month ago and trying to determine in mine has it or not. I know it has a lot of other upgrades, but need to identify the stage 1.
And what is involved in aStage 2 kit
Stage 1 is back plate, air cleaner, fancy screaming eagle cover, air intake tubes that supposedly feed air to the carb.
stage 2 kit I believe involves internals with the motor, correct me if I am wrong?
I did a stage one and big growl pipes on my 93 sporty, man what a difference!
Stage 1 just requires changes to the external engine components: Air intake & pipes to increase airflow, rejetting the carb/installing the EFI download, depending on the model year, and a new ignition module.
Stage 2 gets serious. Now you're changing the guts of the engine by sticking in new cams, milling or buying new cylinder heads to increase compression, new valve springs, 2 into 1 headers, etc.
There's a fairly detailed run-down of the various stage upgrades here, at sportster.org.
