Front turn signal relocation
Hey all, was wondering if anyone has relocated their front turn signals from the handlebars to the forks with the kit HD has. I have an 07 1200CXL and have been thinking of doing this but.. 1. are they as visible for oncoming trafficas on the handlebars and 2. is it a complicated job for someone (me) that has not a lot of experience at doing something like this? Thanks.
RE: Front turn signal relocation
i wouldnt buy the HD kit if i were you, i did that then returned it and bought some clamps off ebay. Something like this:
http://cgi.ebay.com/ebaymotors/41mm-...spagenameZWDVW
The HD kit sucks, and makes the signals stick out too far. I didnt have a soldering gun either, put my wires back together with but connectors, works just fine. Heres a good pointer though, you can do this mod without having to cut the wires, it sure beats soldering them or having to connect them again. I dont remember how i think you have to remove the tank, do a search or maybe someone else can offer some help on how to do that. I wish i had known.
I used the HD kit http://www.harley-davidson.com/gma/g...bmLocale=en_US.
I like the look, I don't think they stick out too far.
I did not have to cut wires or remove the tank. I removed the riser and just re-routed the wires as needed, it was very easy.
There are about 18,324 different kits out there for relocating the front turn signals.
I just went with the Kuryakyn clamp setup that allows the signals to remain pretty close to the tubes. I was running 41mm tubes on my 1200C, but you can also get them in the standard 39mm diameter for the stock frontends.
They were only about $22, and are easy to install.
