Replacing Headlight on 2020 Iron
I have just bought a new LED headlight to replace the stock on on my 2020 883 Iron. I have removed the stock headlight and found that along with the expected wiring harness there are two extra cables attached to the bottom of the headlight unit. Any ideas what they are? My replacement light doesn't have anywhere to attach these.
The position lamp is only present on international models, but the wiring harness is the same on all models. It's purpose is to make the bike visible while left unattended, which is required in some countries. Turning the ignition switch to ACC allows the position lamp & tail lamps to illuminate.
Some aftermarket LED headlights have a halo ring around the headlight. The position lamp connector is utilized to illuminate the halo LED's via an adapter harness connected to the position lamp connector.
It doesn't matter if the bike is keyed, or keyless, both systems have their own separate procedures for entering the ACC mode. The procedure for illuminating the position lamp (on international models) is identical, keyed or keyless, once the bike is in ACC mode.
Do you know what power is coming through these position lamp cables?
