Battery Screws Constantly Loosening
Old 08-29-2019, 07:58 PM
vandykej17's Avatar
vandykej17
vandykej17 is offline
Wow, a lot of responses to read through
1) I do not have spacers. If I do in fact need those, where do I get them?
2) I thought about star lock washers, but since I have a flat washer between the bolt head and the star washer, would it even help?
3) I ended up checking my charging system, and it is only providing 12.48V at idle and 12.98V while revving up. That is way too low.
Digging into the charging system:
So I looked into my manual to check which part of my charging is not doing well. Measuring between my stator plugs and ground are both infinite ohms, not connected in any way. Measuring the ohms between thee two stator plugs is .5 ohms, which does seem ever so slightly high, but something I'm willing to live with. Measuring the voltage between the stator plugs are around 29VAC, which seems correct.
Step 2. To check the regulator unplug it from the stator. Take a test light and clip it to the negative terminal of the battery and then touch first one pin and then the other on the plug that goes to the regulator. If you get even the slightest amount of light from the test light the regulator is toast.
To do this with a meter: black lead to battery ground, red lead to each pin on the plug, start with the voltage scale higher than 12vdc and move voltage scale down in steps for each pin. Any voltage is a bad regulator.
Lastly, according to the tech sticky above, I checked the voltage between the regulator plugs and its between .5V - 1V. That appears to wrong and my regulator might be bad. My question is, would this be causing my loosening cables?
I attached a photo on my positive terminal.
Old 08-29-2019, 08:32 PM
John Harper's Avatar
John Harper
John Harper is online now
Received 1,815 Likes on 1,238 Posts
It looks like you have washers (?) of different sizes, so that could be a source of your problem. It doesn't look like you need spacers from what I can see, but make sure all the washers and ring connectors have the same inside diameter, not off to one side or another. Yours look a bit shifty to me.
Is that copper looking one from the starter? It looks off center of the bolt.
Or is it the silver one just right of the wire with the yellow crimp on?
You should only need/have two wires, one big, and one small. More, and you're probably asking for loose connections. If you have an accessory wire, move it to the terminal block or circuit breaker for power.
John
Old 08-29-2019, 09:11 PM
vandykej17's Avatar
vandykej17
John
I only have 2 wires, the big copper looking one and the small one with the yellow ring terminal. The other 2 items are my split lock-washer and the flat washer that cannot come off the battery bolt. You are correct though, the copper one (going to my starter) has a larger diameter than the battery bolt. I unhooked everything to look at the diameter and realized this is happening to the terminal...
So when I thought I tightened it the other day, I was just squeezing the terminal metal through the "hole" created by the difference in diameter between the terminal bolt and copper ring. Do you agree that's what's happening?
What should I do to fix this? I obviously need a smaller diameter ring terminal, but what do I do about the battery terminal?
Old 08-29-2019, 09:21 PM
RANGER73's Avatar
RANGER73
RANGER73 is offline
Received 6,047 Likes on 3,086 Posts
1. There should have been a washer with a hole the same size as the bolt between the battery terminal and the wire eyelet.
Once the lead pulled through the bolt bottomed out on the lead instead of the ring terminal.
Old 08-29-2019, 09:55 PM
vandykej17's Avatar
vandykej17
For reference this the the difference of diameter. Once places are open tomorrow, I'll get myself a new ring terminal.
Should I just pound that lead back in the terminal?
Old 08-30-2019, 05:58 AM
RANGER73's Avatar
RANGER73
RANGER73 is offline
No, use a washer on the bolt and a pair of channel locks (pump pliers) to squeeze the threaded nut that's in the lead back in.
Don't replace the ring, get the proper washer.
Old 08-30-2019, 06:02 AM
RANGER73's Avatar
RANGER73
RANGER73 is offline
Even the aux. wire you have would work as a reducer to prevent the lead from squeezing through the eyelet
Old 08-30-2019, 06:05 AM
RANGER73's Avatar
RANGER73
RANGER73 is offline
Repair the lug, put the AUX, wire, a Star washer with a small hole then the large ring and another star or regular washer with a small hole.
Longplay (08-30-2019)
Old 08-30-2019, 07:01 AM
vandykej17's Avatar
vandykej17
Okay thanks for all the info, will do this tonight after work. I thought to get the most contact, I'd want the Cooper terminal touching the terminal itself...
Why should I put a star in between the aux and the Cooper? Doesn't a star just prevent turning?
Thanks again,
Jake
Old 08-30-2019, 07:06 AM
Bass Player's Avatar
Bass Player
Bass Player is offline
Received 1,925 Likes on 1,056 Posts
Just a side note. Is that yellow eyelet crimp connector on the red wire a tight connection? That alone has nothing to do with your issue but looks hinky. Sometimes unavoidable, but I wont use them. Solder and shrink tube is your friend in critical areas. Just an observation / question?
Quick Reply: Battery Screws Constantly Loosening
